Here latly my sol hasnt had as much get up and go. and my gas mileage is not as good as what it should be. getting roughly 27-29mpg and thats not getting on it. iv replaced plugs, wires, dizzy cap, rotor button, ignition coil, fuel filter, air filter, battery, and pcv valve. I dont think i have a cel but not sure if it works or not. (it does come on and go off when the key is turned to on)
motor is a d16z6 with 2inch exhaust from the header back, no cat and oem muffler. aem sri 146xxx miles. intake helped with the low end power a bit but still feels like its limp. valve seals are bad so i do burn oil but not sure of how much. and as far as i know the timing belt hasnt been replaced.
i have not done a compression test yet but will perform one this weekend
my guess is o2 sensor but i would think if its bad it would cause a cel. any help is appreciated
