Lowered on Neuspeeds and 195/60/15's
Brewster
The front tire is tucked but I'm sure it wont be this way once it's aligned. I like the look personally. When i replace tires ill probably get some 195/50/15's. Its rubs a little when i hit a bump while turning. These pics were taken at nite. I'll take some better pics tomorrow. What do you think? Good or bad.
Front
Rear
civexspeedy
Waaay too much rake and too low in the front.. Alignment isn't going to change how the ride height is.
XcLuSiVeLy4GoD
ODP
Yeah not proportionate at all... Lower the back and you'll be set...
CHILD
All Day, All JDM
that much rake is from the uneven ground and soft springs. A 195/50 tire would do you well
XcLuSiVeLy4GoD
ODP
That does look better... When you get a chance I wold get the 50 series tires...
Brewster
Thanks!!
I will sooner than I probably want to. I'm sure they won't get my alignment right and I'll have some irregular wear
cgpEJ6
noob
I'd go with 205/50 or 195/55 personally
JohnS.
BANGARANG
I knew I should've gone with the Neuspeed springs back when I was spring shopping. Now I'm stuck with my uneven Eibach Sportline drop that isn't low enough for me.
Looks great! :thumbs up.
Brewster
Alignment guy just called and said I need an aftermarket kit for camber. I've read about this being bs. Can anyone shine lite on this before I get there. Quick!!! Help!!!
wazup_74
It looks good. I say 195/55 or 195/50 both sound good. not sure if you can fit a 205/50 but that would probably be great too.
I hated the 205/40 i had on my 17"
Brewster
I know you all say no camber kit but if I decide to what kit do you recommend? Is this something that needs to be top of the line as well?
Also what do I need to do to the fender wells to prevent rubbing. It appears if I get the tires straight up its going to rub the inner fender cover. Remove this, trim it?
TigBitties
Frame Bangin
i use an omni power camber kit up front, has worked perfect over the past year and faced tons of abuse. survived the smashing through my strut towers
as for the rubbing on the fender liner, its just thin plastic. let it go and let it melt itself through. you will be fine. you can trim it if you want but you dont need to
