Mugen SS2200
SierraSonic
O.o
uhh? is it a silver dildo with a 3 story wing? >.>
NOFX
I'm NOT eran!
A little more info on the SS2200 (which I think is ugly as sin!).
From Supercars.net
Here's a comparision against other factory S2000s too.
Code:
[b][center]In Detail[/center]
Mugen SS2200 (2000 Concept)		Honda S2000 (2000 AP1)	Honda S2000 (2006 AP2)[/b]
price		--------		$30 000 USD		--------
engine		Inline 4		Inline 4		Inline 4
valvetrain	DOHC 4 Valves / Cyl	DOHC 4 Valves / Cyl	DOHC 4 Valves / Cyl
displacement	2190 cc / 133.6 cu in	1997 cc / 121.9 cu in	2156 cc / N/A in cu in
bore		--------		87.0 mm / 3.43 in	87.0 mm / 3.43 in
stroke		--------		84.0 mm / 3.31 in	90.7 mm / 3.57 in
compression	--------		11.7:1			11.1:1
power		192.4 kw		179.0 kw		178 kw
		258.0 bhp @ 8300rpm	240 bhp @ 8300rpm	N/A bhp @ 8300rpm
hp per liter	117.81 bhp per litre	125.19 bhp per litre	125.19 bhp per litre
bhp/weight
torque		219.64 nm		207.4 nm		221 nm
		162.0 ft lbs@7500rpm	153.0 ft lbs@7500rpm	163.0 ft lbs@6500-7500rpm
redline		--------		9000rpm			--------
drive wheels	Front Engine / RWD	Front Engine / RWD	Front Engine / RWD
body / frame	-------			Unit Steel		Unit Steel
front brakes	Disc w/ABS		Vented Discs w/		Vented Discs w/
					Vacuum Assist & ABS	Vacuum Assist & ABS
f brake size	--------		300 mm / 11.8 in	300 mm / 11.8 in
rear brakes	--------		Vented Discs w/		Vented Discs w/
r brake size	--------		282 mm / 11.1 in	282 mm / 11.1 in
front wheels	F 45.7 x 20.3 cm	F 40.6 x 16.5 cm	F 40.6 x 16.5 cm
		18.0 x 8.0 in		16.0 x 6.5 in		16.0 x 6.5 in
rear wheels	R 45.7 x 20.3 cm	R 40.6 x 19.0 cm	R 40.6 x 19.0 cm
		18.0 x 8.0 in		16.0 x 7.5 in		16.0 x 7.5 in
front tire size	225/40R18		205/55VR-16		205/55VR-16
rear tire size	225/40R18		225/50VR-16		225/50VR-16
steering	--------		Rack & Pinion w/	Rack & Pinion w/
					Power Assist		Power Assist
weight		953 kg / 2102 lbs	1250 kg / 2756 lbs	--------
wheelbase	2400 mm / 94.5 in	2400 mm / 94.5 in	2400 mm / 94.5 in
front track	--------		1468 mm / 57.8 in	1468 mm / 57.8 in
rear track	--------		1509 mm / 59.4 in	1509 mm / 59.4 in
length		4430 mm / 174.4 in	4120 mm / 162.2 in	4135 mm / 162.8 in
width		1750 mm / 68.9 in	1750 mm / 68.9 in	1750 mm / 68.9 in
height		1250 mm / 49.2 in	1285 mm / 50.6 in	1285 mm / 50.6 in
transmission	6-Speed Manual		6-Speed Manual		6-Speed Manual
gear ratios	--------		3.13:1			3.13:1
		--------		2.04:1			2.04:1
		--------		1.48:1			1.48:1
		--------		1.16:1			1.16:1
		--------		0.97:1			0.97:1
		--------		0.81:1			0.81:1
final drive	--------		4.10:1			4.10:1
top speed	--------		241.4 kph / 150.0 mph	--------
0 - 60 mph	5.0 seconds		5.5 seconds		--------
0 - 100 mph	--------		14.0 seconds		--------
0 - 1/4 mile	13.5 seconds		14.8 seconds		--------
epa city/hwy	--------		20 / 28 mpg		--------
96_vtec_lude
that should never be done to an s2k again... their should be a law against it.....
rei
jSolo
was it built to achieve top speeds?
sohclubkid
Sick 6/6
From Supercars.net
Code:
bhp/weight
ummm... the compairison isnt really needed.... nothing really changed at all. i think its just someone who made a rediculous show car using mugen areo parts and custom parts.... cuz mugen would never make an S2000 that hideous and pointless... :???:
NOFX
I'm NOT eran!
No, sorry you're wrong. That car was built by Mugen. It's pretty easy to find more info on it. Just search for "Mugen SS2200" or "Mugen SS2200 Concept".
Please do not doubt something just because "Mugen is too good an pure to make something that ugly". This vehicle is styled more towards what is in style in Japan, not America.
And I posted the comparision to show how little it really changed in performance.
thexperiment said:
JDM RICE? rare!
Very. I'ts the only one of it's kind.
all go no show
Half Retarded
and disappointingly, its not even much faster....
I shoulda guessed though, considering that that mugen obviously wouldnt boost it and the sk2 motor is pretty much the maxxed in stock form anyway..
Im just sorta surprised that anyone would like that, be it in japan or anywhere
NOFX
I'm NOT eran!
Japanese modifications are WAY different than US styles. You should go look. It's horrible (imo).
BlackHopeDC5
Is Black Again??? :shock:
Thats what i was thinking.. especially seeing the wheels and the body curving..
I remember that one blue 7th gen civic that was designed to get top speeds and it had similar things done to the body
all go no show
Half Retarded
if it was built for top speed, it most definately would not be an open top like it is.... i think it is just a bizarre show whore.
