[b][center]In Detail[/center]
Mugen SS2200 (2000 Concept) Honda S2000 (2000 AP1) Honda S2000 (2006 AP2)[/b]
price -------- $30 000 USD --------
engine Inline 4 Inline 4 Inline 4
valvetrain DOHC 4 Valves / Cyl DOHC 4 Valves / Cyl DOHC 4 Valves / Cyl
displacement 2190 cc / 133.6 cu in 1997 cc / 121.9 cu in 2156 cc / N/A in cu in
bore -------- 87.0 mm / 3.43 in 87.0 mm / 3.43 in
stroke -------- 84.0 mm / 3.31 in 90.7 mm / 3.57 in
compression -------- 11.7:1 11.1:1
power 192.4 kw 179.0 kw 178 kw
258.0 bhp @ 8300rpm 240 bhp @ 8300rpm N/A bhp @ 8300rpm
hp per liter 117.81 bhp per litre 125.19 bhp per litre 125.19 bhp per litre
bhp/weight
torque 219.64 nm 207.4 nm 221 nm
162.0 ft lbs@7500rpm 153.0 ft lbs@7500rpm 163.0 ft lbs@6500-7500rpm
redline -------- 9000rpm --------
drive wheels Front Engine / RWD Front Engine / RWD Front Engine / RWD
body / frame ------- Unit Steel Unit Steel
front brakes Disc w/ABS Vented Discs w/ Vented Discs w/
Vacuum Assist & ABS Vacuum Assist & ABS
f brake size -------- 300 mm / 11.8 in 300 mm / 11.8 in
rear brakes -------- Vented Discs w/ Vented Discs w/
r brake size -------- 282 mm / 11.1 in 282 mm / 11.1 in
front wheels F 45.7 x 20.3 cm F 40.6 x 16.5 cm F 40.6 x 16.5 cm
18.0 x 8.0 in 16.0 x 6.5 in 16.0 x 6.5 in
rear wheels R 45.7 x 20.3 cm R 40.6 x 19.0 cm R 40.6 x 19.0 cm
18.0 x 8.0 in 16.0 x 7.5 in 16.0 x 7.5 in
front tire size 225/40R18 205/55VR-16 205/55VR-16
rear tire size 225/40R18 225/50VR-16 225/50VR-16
steering -------- Rack & Pinion w/ Rack & Pinion w/
Power Assist Power Assist
weight 953 kg / 2102 lbs 1250 kg / 2756 lbs --------
wheelbase 2400 mm / 94.5 in 2400 mm / 94.5 in 2400 mm / 94.5 in
front track -------- 1468 mm / 57.8 in 1468 mm / 57.8 in
rear track -------- 1509 mm / 59.4 in 1509 mm / 59.4 in
length 4430 mm / 174.4 in 4120 mm / 162.2 in 4135 mm / 162.8 in
width 1750 mm / 68.9 in 1750 mm / 68.9 in 1750 mm / 68.9 in
height 1250 mm / 49.2 in 1285 mm / 50.6 in 1285 mm / 50.6 in
transmission 6-Speed Manual 6-Speed Manual 6-Speed Manual
gear ratios -------- 3.13:1 3.13:1
-------- 2.04:1 2.04:1
-------- 1.48:1 1.48:1
-------- 1.16:1 1.16:1
-------- 0.97:1 0.97:1
-------- 0.81:1 0.81:1
final drive -------- 4.10:1 4.10:1
top speed -------- 241.4 kph / 150.0 mph --------
0 - 60 mph 5.0 seconds 5.5 seconds --------
0 - 100 mph -------- 14.0 seconds --------
0 - 1/4 mile 13.5 seconds 14.8 seconds --------
epa city/hwy -------- 20 / 28 mpg --------
NOFX said:A little more info on the SS2200 (which I think is ugly as sin!).
From Supercars.net
Here's a comparision against other factory S2000s too.
Code:[b][center]In Detail[/center] Mugen SS2200 (2000 Concept) Honda S2000 (2000 AP1) Honda S2000 (2006 AP2)[/b] price -------- $30 000 USD -------- engine Inline 4 Inline 4 Inline 4 valvetrain DOHC 4 Valves / Cyl DOHC 4 Valves / Cyl DOHC 4 Valves / Cyl displacement 2190 cc / 133.6 cu in 1997 cc / 121.9 cu in 2156 cc / N/A in cu in bore -------- 87.0 mm / 3.43 in 87.0 mm / 3.43 in stroke -------- 84.0 mm / 3.31 in 90.7 mm / 3.57 in compression -------- 11.7:1 11.1:1 power 192.4 kw 179.0 kw 178 kw 258.0 bhp @ 8300rpm 240 bhp @ 8300rpm N/A bhp @ 8300rpm hp per liter 117.81 bhp per litre 125.19 bhp per litre 125.19 bhp per litre bhp/weight torque 219.64 nm 207.4 nm 221 nm 162.0 ft lbs@7500rpm 153.0 ft lbs@7500rpm 163.0 ft lbs@6500-7500rpm redline -------- 9000rpm -------- drive wheels Front Engine / RWD Front Engine / RWD Front Engine / RWD body / frame ------- Unit Steel Unit Steel front brakes Disc w/ABS Vented Discs w/ Vented Discs w/ Vacuum Assist & ABS Vacuum Assist & ABS f brake size -------- 300 mm / 11.8 in 300 mm / 11.8 in rear brakes -------- Vented Discs w/ Vented Discs w/ Vacuum Assist & ABS Vacuum Assist & ABS r brake size -------- 282 mm / 11.1 in 282 mm / 11.1 in front wheels F 45.7 x 20.3 cm F 40.6 x 16.5 cm F 40.6 x 16.5 cm 18.0 x 8.0 in 16.0 x 6.5 in 16.0 x 6.5 in rear wheels R 45.7 x 20.3 cm R 40.6 x 19.0 cm R 40.6 x 19.0 cm 18.0 x 8.0 in 16.0 x 7.5 in 16.0 x 7.5 in front tire size 225/40R18 205/55VR-16 205/55VR-16 rear tire size 225/40R18 225/50VR-16 225/50VR-16 steering -------- Rack & Pinion w/ Rack & Pinion w/ Power Assist Power Assist weight 953 kg / 2102 lbs 1250 kg / 2756 lbs -------- wheelbase 2400 mm / 94.5 in 2400 mm / 94.5 in 2400 mm / 94.5 in front track -------- 1468 mm / 57.8 in 1468 mm / 57.8 in rear track -------- 1509 mm / 59.4 in 1509 mm / 59.4 in length 4430 mm / 174.4 in 4120 mm / 162.2 in 4135 mm / 162.8 in width 1750 mm / 68.9 in 1750 mm / 68.9 in 1750 mm / 68.9 in height 1250 mm / 49.2 in 1285 mm / 50.6 in 1285 mm / 50.6 in transmission 6-Speed Manual 6-Speed Manual 6-Speed Manual gear ratios -------- 3.13:1 3.13:1 -------- 2.04:1 2.04:1 -------- 1.48:1 1.48:1 -------- 1.16:1 1.16:1 -------- 0.97:1 0.97:1 -------- 0.81:1 0.81:1 final drive -------- 4.10:1 4.10:1 top speed -------- 241.4 kph / 150.0 mph -------- 0 - 60 mph 5.0 seconds 5.5 seconds -------- 0 - 100 mph -------- 14.0 seconds -------- 0 - 1/4 mile 13.5 seconds 14.8 seconds -------- epa city/hwy -------- 20 / 28 mpg --------
No, sorry you're wrong. That car was built by Mugen. It's pretty easy to find more info on it. Just search for "Mugen SS2200" or "Mugen SS2200 Concept".sohclubkid said:ummm... the compairison isnt really needed.... nothing really changed at all. i think its just someone who made a rediculous show car using mugen areo parts and custom parts.... cuz mugen would never make an S2000 that hideous and pointless...
Very. I'ts the only one of it's kind.thexperiment said:JDM RICE? rare!
Japanese modifications are WAY different than US styles. You should go look. It's horrible (imo).all go no show said:Im just sorta surprised that anyone would like that, be it in japan or anywhere
Thats what i was thinking.. especially seeing the wheels and the body curving..rei said:was it built to achieve top speeds?
