BenjoNi94
Hi all,
recently I've become an owner of a Honda Civic 4th gen Sedan 1.6l
it's been all great till lately,
car has 270k kilometers on clock,
engine light is on, checked the codes and it is 6-9
so far I'll be picking ECT sensor tomorrow and replacing it, hopefully u guys could give me some recommendations on how to solve next problems:
car is starting heavily it takes it roughly 7seconds
when cold completely car starts faster
right wheel sounds like it's constantly bumping when wheel turns right
car idles at 500rpm which really scares me
also when coming to a stop or shifting gears(sometimes) rpm would drop so hard and car would shut down unless I react really fast and press the clutch and gas really fast and then it won't turn off but rpm would be at like zero and then rise up which is reaaaaaly annoying.
also what I've noticed is that these stalling problems don't happen when I refill only when my fuel is below 1/4 of tank so could it be that my gauge is lying to me about the fuel level
plus when these things happen to me I've noticed that if I manage to stop without shutting down and pump the brake pedal the rpm gauge would climb to between 800-1500 rpm.....
and yeah also when I have this trouble I've noticed that when I press gas coming from a stop the rpm would first drop then rise which is really triggering when I need to slow down almost to a stop and then cars in front of me move as my rpm is already low enough....
on top of everything yesterday I've noticed oil leak when I've moved my car on different parking space (5m away)...
the thing is, oil is only leaking when car is running, did not happen before, went back to parking space I was before I moved it and nothing was there.
the leak seems to be coming from center/passenger side of car
so yeah haha any opinions, I am willing to work on this car as I like it really much so yeah
+mpg is horrible but from what I've researched so far that is due to ECT sensor failure which I'm replacing tomorrow
Sent from my HUAWEI TAG-L01 using Tapatalk
