When I start the car it likes skips at idle and the check engine light flashes, and the fuel relay makes a click noise along with the engine light then after it does it a few times the car goes steady but high idle and the engine light stays on, and I lose my rpm and thermostat gauges but speedometer still works and as I try to drive the car it cuts out at really low rpms so I have to shift way to early
This is the info you should have provided in the first place. Also you posted this in the how-to section. This is not a how-to. I've moved this over to the 7th gen section for you
