kidivory
I have posted a couple of days ago in the tech section but not to many people seem to see it so I thought I would try in the new section since I am new to this site. Here is what I posted;
Hey guys new to the site, well at least registered anyways. I have a 2000 Civic D16y7 5 speed, that I just recently installed an aftermarket Intake Manifold and Header, that's Rite I said Header not HEADERS! Sorry That's just a pet peeve of mine when people call there header, headers on a 4 cyl:.. Anyways, to the problem, I am hearing a weird ticking or light knocking noise from inside the car. It only happens when you hold the RPM's at a steady. If you let off the gas it goes away, if you get on the gas it goes away. You don't hear it at all when mashing on it or downshifting just at a steady even throttle, no matter where the rpm range is if it is steady it comes around? The only thing I have done real recent is installed Polly Urethane Shifter bushings, But I can't see that being the problem. I need help Guys, I have no Idea what it is, and when it does happen from time to time at stand still (idle) when I get out and try and locate it you can't hear it from outside Any thoughts or suggestions would be greatly appreciated, Thanks in advance.
Here were my follow ups;
it's not the valves as I just adjusted them besides valves are usually noisy all the time and may get a little louder as you rev the engine. But this noise is only at a steady rpm, and after just driving it I would say it is definitely between 2k - 3,500 rpm range I know its weird, Trust me I have heard all kinds of sounds from my integras to my accords but this is a first for me. It's like a cross between a clicking and a rattling sound if that helps.
First I would like to thank all of you who have taken the time to chime in on this thread and help! As far as the heat shields go, I am pretty sure it's not the shields because when I put the header on I connected it to the stock exhaust and looked it over and seems to be plenty of clearance there.
I would like to be able to pin point it by having a buddy hold the throttle but it won't make the noise unless it's being driven?
GreenSpeed503, It is not detonation I am almost 100% sure of that. I did install an accell High Output internal coil recently so your reply sparks my interest no pun intended. I am wondering if I may have skipped over one of the valves or just didn't double check the clearance? I did it by myself and was in kind of a hurry and this being the first SOHC motor that I've done valves on it was more difficult to see the cam and it's position when turning and adjusting? I don't know guys, I have thrown 2 codes since my work to the car, 1 = P0420, which I fixed by taking the 02 out and zip tying it to the shift linkage that doesn't move. the 2= P0505, which I fixed by adjusting the Idle that I previously adjusted up to get rid of the intake whistle, but now it is back down the whistle is back but no codes! Please help, it's not that the car is running bad but it is annoying as hell! Thanks Guys!
So maybe I will get more of you Veterans on here to chime in or anybody with some sort of idea, Thanks Again
