Normal Cooling System Operation
Yobo
I have a Honda Civic FD1 2007 Auto Sedan with an Engine Watchdog fitted as an aftermarket protection audible warning against engine overheat and low oil pressure. This device has a digital engine temperature readout.
I'm just wondering if my cooling system is operating within normal specs.
With the A/C switched off and from cold I idled the engine and noted the both fans kicked in at 94 degrees C. Is this normal operation?
I turned the engine off and noted both fans freewheel to a stop. The radiator fan came to an abrupt halt followed by the A/C fan which continued to freewheel a few seconds more. I spun the fans by hand and the radiator fan seems noisy and rough. Is it possible to replace the bearing in this motor? Otherwise I'll get a whole assembly from ebay here in Australia.
I normally run the car with the A/C on and both fans run when the engine is started from cold.
Thanks.
motorjunkiematty420
Id get a new radiator fan than try to rebuild it maybe aftermarket? Some race cars have aftermarket switches that turn on the radiator fan itself than when the ecu tells it. Did you mess with the tune? Some people tune theres for the fan to come on immediately instead of waiting for the thermostat to open its passages. Id say If the engine temperature dashboard needle doesnt go in the red zone you should be ok. good luck
Larkin
I heard that many motorists besides me also try to protect the car from various damages. For example, I have managed to do it without any problems, because really here you just need to have the necessary information, so to speak, get the necessary insides and then there will be absolutely no problems in order to somehow protect the car. For example, I recently studied a very interesting article where they say that there is such a cool thing as a kangaroo, you can see here avtotachki.com/en/chto-takoe-kenguryatnik-i-zachem-nuzhen/ . I didn't even know that this stuff is hooked to protect the car from various damages on the road. How cool for me it is, so also look, I think it will be really useful now. In addition, it's easy to put this one with your own hands, it says just that, that is, you don't have to carry it to the service station and put it there for a lot of money, because small amounts are usually not taken there. I do not know how much it will help to protect the car, but what if?
