Offset Wheels?
AznDude
i was wondering what the #'s mean when it says the wheel is offsetted? thx.
imazn
i just posted it here the other day. http://www.clubcivic.com/board/viewtopic.php?t=636
how it helps.
ComCool
Muhahaha...
When a wheel says 17x7 is the 7 at the end the offset or?
bklynEG
FTW!!
205 is the width of the tire the 40 is the sidewall and the 17 is the diameter of the wheel
ComCool
Muhahaha...
Yeah I know that, but don't get the 7 and 7.5 thing. If that is the width of the rim, a 205 would not fit 17x7. 7" in mm is 177,8 right? :|
bklynEG
FTW!!
yeah they make 205's for 17's. 205 is 205mm. and yes the 7 is the width of the rim. thee 205 is the width of the tread not the wheel
ComCool
Muhahaha...
I know they make 205 for 17". But the 205 in the tire code is that tire width right? How will a 17x7" rim then fit, when 7" in mm is 177.8mm not 205mm. Or is there just somthing i'm not getting here?
DredwerkZ
Irish Devil
I thought the second number, for example 17 x 7.5 is the offset. And offset is the distance from its hub mounting surface to the centerline of the wheel.
bklynEG
FTW!!
you're right about what the offset is, but that number isnt on the tire, the offset number should be stamped somewhere on the inside of the rim.
bklynEG
FTW!!
in other words the wheel offset is on the wheel not the tire since you can use the same tire on a number of different offset wheels
DredwerkZ
Irish Devil
nobody ever said anything bout the 7 or 7.5 bein on the tire....he said wheel...
ComCool
Muhahaha...
I know all that, and now know that tha 7 and 7.5 is the offset, you just sayd it was the width of the rim when i asked before.
bklynEG
FTW!!
on a 17x7 rim the 7 is for the width of the rim. typically for a honda , civic for example the rims offset is something like 38, 40,or 45mm.
