Power Issue, CEL P1129
Mr.Baker
Mr. Search
Having lack of power issue engine code P1129 can someone help
Have you looked up to see what the code is?
Do that, then trouble shoot from there.
Probably not a MAP sensor issue. The sensor sends signals to the ECU based on manifold absolute pressure (hence, MAP). This is based on vacuum. Higher vacuum = higher voltage sent to ECU.
So... any vacuum leaks? How is your idle? I would start by cleaning the IACV.
Lee203rd
I did clean it still the same thing but the light didn’t come on it’s been a day and a half no but still no power
And my idle is up and down can I find a vacuum
This is a sign of a vacuum leak.
What else have you tried? Stock motor? What engine? The more details the better, especially with what you've tried so far.
Lee203rd
02 Civic 1.7L v-tec I get a new map sensor I check the pcv I Cleaning the IAC I removed the power cam pully to see if my mine seal was leaking
civteck
Color wire? Voltage to ground on each? KOEO? KOER? need to know the specifics if we can help.. grammer check and pics would be great..
Sent from my boujea ass phone
