machonda91
So my '91 Civic DX 1.5L DPFI Automatic is throwing off engine code 14 about Idle Air Control. The resistance on the IACV was out of whack, about 2 ohms, and then I cleaned and reset the main ground under the battery. This caused the IACV to measure normal resistance of 14.1, within specs of 8 to 15 ohms. Then I reset the ECU and cleared codes. It ran fine for a few miles and then I shut it off and charged the battery with a 6W mower charger overnight. Got into it today and it's just like last week - check engine light, starts but won't continue running. It will run if I keep my foot on it, for about 20 seconds, then stall out. So I am thinking either the charging activity is overloading something or causing the ground problem again. Or perhaps the IACV gets shorted by charging? I plan to clean the next ground on the negative battery cable, I think it is connected to the transmission. The car ran very well in March, but I do charge the battery because it doesn't get run much. As the fuel, ignition system, were both fully cleaned and replaced a year ago, I think this is a grounding problem of some sort, or an ECU issue. Any advice appreciated.
