removing small dents
renegadex96
Captain Obvious
#1
Somehow, someway, i'm really not sure how :roll: my hood has got some really small dents protruding outwards, almost like knuckle marks, like someone hit the inside of the hood. Anyone know of a way that those could be fixed, without pounding them back down or replacing the hood (which is one of my long term goals anyways......)
CivicEX13
CC's Valve Cover Guy
#2
is the paint cracked at all on them? if not take a hammer and put some masking tape or some kind of tape on the hitting side and just lightly tap the dents...they may not go all the way away but you could make them look somewhat better depending on how bad they are
Trey99EK
#3
Take your thumb and try to push it down? Sometimes the smallest dents are the worst to remove. I have a few and I can't push them out, it sucks.
renegadex96
Captain Obvious
#4
Tried pushing them down, sucks cause it's in a spot in the middle of the hood. If i apply too much pressure, it pushed the hood down around it. No cracked paint or anything, just protruding dents. I'll give that hammer idea a shot, see how that turns out
LowNotSlow
Aqua Teen Christmas Force
#5
Jesus be careful with that hammer. If you're going to do that make sure you support the back side of what your hitting.
renegadex96
Captain Obvious
#7
Oh for sure, hitting very very lightly. Think using one of those rubber mallet things would be a a better option?
rexxxgirl
i want a new hatch!!!!
#9
Trey99EK said:
I would use the mallet. Put the block wrapped in a towel behind it to absorb some inpact.
yea and if you get the protruding ones banged out, and cause more damage, whatever you do, you should be able to at least fill it.
NOFX
I'm NOT eran!
#10
Don't use the Dent King. i told my ex, but he boutgh it anyway. What a waste of money. Even if it did work, it's not supposed to work on smaller dents.
From what I hear abotu hood though, dents are nearly impossible to remove because of the ribbing behind it.
Also, often when you try to remove a dent yourself you will crack the paint.
I say save up for a new hood.
