Skunk2 74mm B-Series Black Series Throttle Body
Skunk2 is proud to introduce its 74mm Pro Series Throttle Body for Honda's B-series engines (also compatible with F- and H-series) in its exclusive, Black Series finish. Skunk2’s 74mm Pro Series Throttle Body is designed to be used with Skunk2’s Pro Series Intake Manifolds as well as other aftermarket intake manifolds for bolt-on horsepower and torque gains by maximizing engine airflow.
Skunk2 throttle bodies undergo an extensive design and testing process to produce a throttle body that doesn't just provide more flow but retains smooth drivability and OEM throttle characteristics. Each Pro Series Throttle Body is designed using the latest CAE (Computer Aided Engineering) tools, which results in a unit that exceeds industry standards. Pro Series Throttle Bodies are also CNC machined from forged, billet 6061-T6 aluminum and hard anodized for durability in Skunk2’s signature Black Series finish. Additionally, Skunk2’s unique design relocates the MAP sensor underneath and eliminates the OEM water passages for cooler operation and a cleaner appearance. Pro Series Throttle Bodies are also compatible with OEM throttle cables, which simplifies installation. Each Skunk2 Pro Series Throttle body also features sealed bearings for smooth operation and a genuine, integrated Skunk2 badge. All necessary hardware and a new throttle body gasket are included for trouble-free installation.
A larger throttle body is key to producing additional power throughout the powerband on modified engines with increased airflow demands. Skunk2’s Pro Series Throttle Bodies for B-series engines feature a large, 74mm bore, which results in significant horsepower gains throughout the powerband on heavily modified, naturally aspirated applications and even more on forced induction ones.
FEATURES:
Large 74mm Bore
Black Series Finish
Compatible With OEM Throttle Cable
CNC-Forged 6061-T6 Billet Aluminum Construction
Sealed Bearings For Smooth Operation
Eliminated Water Passages For Cooler Operation
Integrated Skunk2 Badge
Part Number:
309-05-0065
Available for purchase in the CC Store:
http://www.clubcivic.com/store/skunk2-pro-series-throttle-body-309-05-0065_p5943.html
FEATURES:
Large 74mm Bore
Black Series Finish
Part Number:
309-05-0065
