it started out with a bad exhaust leak, found out the manifold and cat was badly cracked so replaced them! code reader said po303 and po113 so i replaced injectors and plugs and the IACV from amazon for 34 bucks.. was ilding great but no power driving it. checked fuel pressure, 34psi idling and i think 40 with hose off of FPR, new fuel filter, checked fuel filter and fuel pump in the tank and they look new. so i cleaned the oem IACV and put it back on and same thing, took the throddle body off and cleaned it, the TPS on this one is rivited on so couldn't check it.. i have pulled off each injector plug and it ran rough so i would think they are working and put the ohm meter on the injectors and checked good ? compression test shows 1-155 2-145 3-150 4-156 so the missfire on 3 i used another plug wire on it and no change.. dist. ? TPS. ? 02 sensor ? has new crank sensor months ago. would the cracked manifold and cat mess up the 02's or other sensor's.. so after checking out some videos on utube i thought maybe check into the tps i checked the plug going to the tps and i have ground, the middle wire i get 0.4 and wot is 4.65 and nothing from the power side.. with key on with test light no power, but if i put the test light clamp on the pos side battery and touch the power side of plug it lights up, isn't this bad ? is that a direct short ? but what is driving me crazy is when the car is idling its seems fine, but when i give it throddle in park it will rev but stumble and trying to drive it forget it! is the goal to have power from a test light or 5 ohms on the power side of the tps plug.. sorry just trying to learn this wiring and ohm meter stuff.. i'm used to working on classic mustangs and not these honda's, thanks, and hope i didn't confuse you too much!
