JDMSTYLE2000SI
Hey CC, got another problem for anyone that dare attempt to solve it...Ok so this past week I was doing a minor tune-up on my sister's 94 civic sedan. Everything was moving along fine until I tried to remove the cylinder one spark plug. It moved about 3/4-turn and seized up and now it won't turn either way (left or right). So now there is a slight gap between the plug and the combustion chamber and it's causing a hesitation during acceleration.
I'm assuming the cause of this seizure was an incorrect installation that damaged the threading, however, I'm sure that I can use brute strength and the added help of a leverage bar+breaker bar to remove the plug. My fear is that I will further damage the threading and be unable to install a new plug. So....my question is, if I remove the plug and then remove the entire cylinder head (to inspect for cracks and/or the damaged threading) would it be possible as well as safe to re-thread the damaged threading?
As always any and all input is greatly appreciated.
