PhreakyPyro
Alright this is what I have.. driving down the road and in about a 10 second period this happened... started to act weird then stall (kinda sounded like a diesel idling) and died... lucky I managed to get to the side of the road safely... anyways now this standing issue.. I can put the key in start it up and it fires right up runs for about 2 full seconds then the car stalls (again sounds like a diesel idling) and dies... I am a self taught "parts swapper" I do not have much if any experience troubleshooting... I need a direction to start in I have seen alot of forums about the timing could be off 1 or 2 teeth.. I hear the fuel pump the main relay I don't think it is fuel I checked my spark plugs (visually) they were not worn lightly dark not much carbon build up.. where the coil packs slide in to the bottom side of the plug was so clean it shined... (to be honest the cleanest I have ever seen ever...) I have also seen where it may be a crank or a cam sensor but can I check that without replacement..? The timing chain cover gasket is only 20 bucks is it worth starting there and looking I need some direction I'm going to get a computer tomorrow to see if it has codes and if so which... any advise will help...
