versatyl86
I bought a 96 Civic DX. I ripped it apart and realized the steering column was tweaked to the right. (probably broken into I know.) I replaced it with a steering column form the junkyard and made sure it was straight. Installed it and still crooked. I noticed something while trying to adjust it and messing around with it and am curious if anyone has had tried this solution. the 17mm bolt that goes to the height adjustment lever has a bracket that goes over it and is held by a 10mm bolt just behind it. Has anyone tried to see if the bracket allows you slightly adjust the rotation of the column? I'm going to the junkyard again tomorrow to see if I can find he bracket as mine is bent, but am curious if anyone has tried this method.
