Suspension help!
Zombie121
I have a 99 civic ex. I just installed new rear control arms, camber kit, new shocks, and adjustable coil over sleeves. The issue is I can’t get the left rear to lower. I adjusted both the right and left rear all the way down as low as it will adjust and the left rear has a 2” wheel gap between body and the right rear wheel is all the way down over the tire??? Please help. I thought it might be that I tightened the control are bolts while car was off the ground but I loosened everything up and dropped car and retightnened everything. If you jack up both side of the car the springs are loose. I know that it’s notnsomething to do with that??
nd4sped
Moderator
You need to adjust the rings down 2" on the sleeve. Bottom ring is the height adjuster and the top second ring is the lock.
