Swap d15b7 to d16y8 problems
drix
Hello everyone ! Im Darek. I have Civic EJ2 LSi about 5 years. Now I swaped engine from D15B7 to D16Y8 and I have problem with start the engine...
What I did:
  • ECU P06 modiffication: added VTEC and chip with injection map from D16Y8
  • engine harness OBD1 from D15B7 with added wire to VTEC control (pin A4 in ECU)
  • Inhaust and Exhaust manifold from D16Z6
  • distributor TD41U (OBD1, D15B7)
  • spark plug cables D16Y8
  • engine block and head D16Y8
I read that engine D16Y8 can work properly via OBD1... but i cant start engine.
What I checked:
  • engine timing gear is set properly
  • fuel on the spark plug - is
  • spark on the spark plug - is . I checked it on all the spark plug cables
  • ECU in service mode doesnt report errors
I have no idea what is wrong.
I will be grateful if someone tell me what I should check.
Greetings !
Mr.Baker
Mr. Search
When you put the key in and try to start it, what exactly does it do, or not do?
drix
Could you see my video from google drive??
photos.app.goo.gl/LZUqmfgbCguHbnLY9
