Swap from auto to manual
Jdm2326.
Hi everyone I need help if possible guys, I made the swap from auto to manual on my ek but now I got a brick wall, can’t seem to started... new clutch, alternator, stared motor has 102k and everything is connected... what can it be I’m getting frustrated...
:welcome:
Can you provide more info? Car gets power? Does it crank at all?
Did you rewire the 14P plug wires correctly? I think you just need to cut that plug (it's the auto shifter plug) and solder them together.
Check your grounds, etc.
It would also help if you told us what year / model / engine you have.
Jdm2326.
I did cut the plug and I did put the 2 black cable together but there are not solder, all the ground cable have been check. Is a 98 civic ex coupe still have the automatic ecu and the car is vtech.
The only thing that I can’t find is the plug for the clutch that goes connected on the bottom of the dash board and also I change the cluster to manual so I don’t know what else to do?
Thanks
