Thats right. i've got water in my fuse panel under the dash. i found this after sitting at the bank not able to go anywhere. the car would start right up and idle but it would idle very low. at about 1k. whenever i pushed the gas it would rev for a split second and then drop to 1k again. if i held he peddle all the way down (i know stupid idea) it would rev to about 4k and then down to 1k about every 3 seconds or so. at first i thought maybe my fuel pump was failing but sence i was stuck and couldnt go anywhere i started searching. i looked under the dash and saw a shinny substance in between the fuse panel and its casing so i squeezed the casing and water just started to pour out. once it stopped dripping i tried the gas again and it worked like normal. so...... my question is, where is this water coming from? i'm thinking one of two things. either a leak outside of the car (its been snowing and raining) or possibly condensation, but it was alot of water so im doubting condensation right now. anyone have any ideas as to where this may be coming from? or any ideas to keep this thing dry if i cant find the leak?
