What's wrong with my car? (audio recording inside)
sedna6
Ok guys, I bought this Honda Civic 2005, and I only noticed this after I bought it, when I test drove it -- I didn't hear it..
my friend tells me it's a Wheel Balance problem...
if you have headphones, put them on as you'll be able to hear it better.
http://soundcloud.com/sixamsedna/vibration
listen carefully to 0:10 - 0:16 and 0:42 - 0:46
it's this vibrating/pulsating sound.. it's not a Wheel Bearing problem, that one is a totally different noise, I'm thinking this is Wheel Balance myself, but I'm not that knowledgeable about cars anyway.
What do you all think it is?
Also I might add that the car is out of alignment...it pulls to the right, could it all be causing it?
civicspencer
You have a bomb in your car!!
But I can hardly hear it, I'm puzzled
rayaccord101
yea i cant hear what ur talking about cause from what i heard, it seems like normal driving sounds, and that one part with the ticking that was obviously ur turn signal thats all i heard :-( sorry bro maybe if u gave us an actual video instead of audio we can see what ur doing as ur driving
io_303
NIFOC
I can kinda hear it. Do you feel vibration or just an annoying droning sound. Other stuff to look at:
Wheel bearings
Dragging brakes
JohnS.
BANGARANG
- Check your lug nuts and make sure they're tight
- If your wheels were out of balance, your car should shake constantly, especially at higher speeds. You would feel it in your steering wheel as well and especially when you brake.
- If your car shakes only when braking, it's more than likely your brakes (rotors)
- If your car shakes only at certain times/speeds/conditions, it could be something else. Look at the suspension components under the car or have it inspected by a mechanic.
kid2006
All I can hear is the smoothness of engine and your turn signal. lol.
does your steering wheel jerks lightly?
kid2006
also make sure your lugs are TORQUED.
EM1Nate
EM1N8's 99 Si
To me it sounds like warped rotors and brake pads that have been glazed. I think the previous owner may have been hauling some A** and rode his brakes. From what I can hear in the recording its only when you hit your brakes.
