Which computer/ECU would be best for my application?
tye
S.T.U.D.
#1
Well Im working on a mini me swap, and I already have a d16y8 head, with a d16y7 bottem. My buddy told me he has a ZC computer/ECU that would work fine, but I'm not really sure if it's my best ebt. Is there a better fit that I should look for instead of that? I just want something that would be the very best for my project. Thanks alot.
chadi
chuatZ
#2
you are probably best off using the p2p ecu, the 96-98 version with the obd2a...using the zc/p28 ecu will be a problem if emissions is a concern there, but the p28 ecu (92-95 d16z6) ecu is the most commonly used ecu
tye
S.T.U.D.
#3
Emissions are not a problem here. So I should be on the look out for a p2p obd2a ECU ?
chadi
chuatZ
#4
then id look for a p28, get a obd2/obd1 conversion harness, that way you can get it tuned
tye
S.T.U.D.
#5
hmm.. so my friend selling his zc ecu is not a p28?
if i do this with the computer and harness, will i need to change my intake manifold and throttle body or can i just use my stock d16y7 set up?
oddeb707
R.I.P Stephen Jackson
#8
you need a p28 ecu and jumper harness. i have a p28 if u wanna shoot me an offer.
chadi
chuatZ
#9
both the p2p and the p28 will work, if you use the p28 you will need a conversion harness, and the p28 is more tunable
tye
S.T.U.D.
#10
so if I do get a p28, would I need to swap for a si intake manifold?
chadi
chuatZ
#13
it doesnt make that huge of a difference...when you go buy parts, just know which parts you need..dont buy an intake for a vtec motor, even though you have one, youre still using the y7 downward IM..
if you are not looking to squeeze every pony out of that motor, the y7 manifold will work perfectly fine. except wiring issues, i cant remember what it was, but one of the sensors runs three wires, but on the 5spd p2p that sensor only has 2 wires
