Frostyy
NOTE: I posted this in the 9th Gen section already, but figured this might be a better place for it.
Hey guys, I'm an active member over on Acurazine.com (Frosty), but I figured I'd post this review here as well since my friend drives an SI, and recently upgraded his lower fogs with these same LEDs.
My search for LEDs started after I became sick of the Nokya Hyper Yellow halogens that I had in both my upper (factory) fogs, and my lower (Inspire) fogs. I was just tired of the yellow, JDM-look in general. So I originally planned on getting white LEDs for the upper fogs, and white HIDs for the lower fogs (That's what most people do). I knew the upper LEDs would never be as bright as the lower HIDs, but putting HIDs in the upper fog housings really isn't a viable option.
There are quite a few LED options out there, but I would dare to say that I've found the absolute best one, both in terms of color, and brightness. I stumbled across it while searching on a popular lighting site, and they were listed for nearly $100. They caught my attention because they were new (2014), and the specs looked quite impressive. I was able to find the same LEDs elsewhere for a much better price, and decided to give them a shot.
The install was a piece of cake- a simple plug-and-play design.
When I turned them on for the first time, I literally thought I had turned the HIDs on by mistake- that's how insanely bright these things are! (4800 lumens)
Upper fogs / DRLs ONLY
I was so impressed with these LEDs, that I ditched the idea of getting HIDs for my lower fogs, and bought another set of these LEDs instead.
Lower Fogs ONLY
About a week ago, one of my factory HIDs burned out, so while I waited for my CBIs to arrive, I had to use only my upper and lower LEDs to light the path. I had no problems whatsoever. I forgot the HIDs were even off.
Upper Fogs / DRLs and Lower Fogs ONLY
These LEDs matched my factory (color-shifted) HIDs quite well, but they are a PERFECT match for the Osram CBI HIDs. I convinced my brother to get a pair for the fogs on his 2011 335i (which also has CBIs), and they couldn't be a closer match. My mom also got a set for her 2011 SRX fogs. They are a great match for her HIDs also.
BEFORE
AFTER
My buddy just got these for his 2012 SI fogs. He loved them so much that he ordered more for his low beams as well. They will be here next week.
Here is a picture I took after installing my CBI HIDs. They are a very close match now, but I'm anticipating a perfect match after the CBI break-in period.
Lower Fogs ONLY
BEFORE
AFTER
Sooo... What do you guys think?!
