Y8 short block $75 - lots of pictures
Status
Not open for further replies.
Charlie Moua
#1
Shipping will be about $70-85 with fedex ground
I have about 150 vouches on honda-tech alone so please feel free to ask questions and buy with confidence.
I took this out of my sister 99 civic ex auto (202K)
motor sized due to bearing so i trashed the crank, pistons & rods.
I would not sell anything that I wouldn't feel safe using my own.
No holes in block
No damage to mains or walls
Comes with :
+ main caps + bolts
+ Ooil pump & bolts
+ MINT oem water pump & tensioner (was replaced 8K ago)
+ alternator brackets & bolts
+ alternator (you can pick from obd1 or obd0 * not in picture but tested at autozone already)
+ water pipe & thermostat housing with bolts
+ oil pickup with bolts
+ oil pan & bolts
+ dip stick & tub
+ crank pulley & key
+ A6 timing belt gear (to avoid using y8 gear with crank angle sensor)
+ driver side mount
+ oil pressure sensor
+ stock oil drain can
DOES NOT HAVE:
-crank
- rods
- pistons
- bearings
- oil pan gasket
- rear main seal (but oil pump is good)
- knock sensor
$75 for all of it.
Normally i'd just sell the y8 oil pan for $40
Perfect for someone who wants to build their block over the winter !
It will come with all parts listed above bolts up for easy transport & shipping.
no lose items
I can have it hone (stock 75mm) or bored to 75.5mm or 76mm for $85 & hot-tanked for $50 extra (block/oil pan, main caps too)
Below are pictures of my brothers B20 that was just honed (not hot-tanked) so you get idea of how clean it will come. NOTE: I didn't opt to have the outside cleaned cause it was already clean when it came in last year from japan.
Status
