Yet another intake question
Linguistics
Live Manikins
I just wanted to know if it really matters, performance wise, between which company you purchase a cold air/short ram intake from? is it really worth the difference in price when buying a knock-off brand over a very well known brand. and how much more effective is a cold air over a short ram...if any
Handlebars
None Taken.
the best answer i can give you is: it depends. for short rams, they are all basically the same, the difference in gains is absolutely minimal. for a d series civic, the gain of a ram air is only a hp or two. same with the b series. on the k20 on the other hand, a short ram will give you 10whp by itself. as for cai's, the difference is a bit more pronounced, but your only talking a maximum difference of 2-3 hp between the best and the worst models for b and d series engines. the gain is usually something like 3-6whp max. the k20 has shown to gain over 20whp from a well designed cai. obviously the honda engineers goofed big time on the intake design for the k20, leaving in that much restriction should be illegal. if you took two identical cars, one with a no name cai and one with an aem v2, you wouldnt be able to feel the difference. your talking a difference of 1-2% which is just not detectable in driving. only on a dyno will you see the difference. i rarely say this, but when it comes to intakes, get the cheapie. as long as the filter wont break up or the thing fall apart for no reason, there is little justification for spending the few hundred dollars difference between a high end cai and a no name cai, unless you want to squeeze every last bit of hp from your motor, or your doing a very involved n/a buildup which needs every bit of air you can feed it. a cai is definitely better than a short ram, it sucks up cooler outside air instead of engine compartment air, which is hotter. this is the source of the extra hp, and it also helps prevent detonation by lowering intake temps.
Team 4R
Dr. DIY
i concur........ it doesn't matter. just make sure you get large enough piping diameter (2.5"+)
Linguistics
Live Manikins
so since i have a no-name short ram, the kid with the super expensive short ram wouldnt really be that much better off than me?
Handlebars
None Taken.
depending on the filter, he might have a half hp on you, or possibly you might have a half hp on him!
panuwat
Lost Honda
are you encouraging me to take one of those fake me out looking cold air intakes from ebay instead of injen's ??
silverctr
Whaddaya lookin' at?
From my research, either go with a CAI or the stock intake with a K&N filter. Both of those are the best bang for the buck. I rember seeing somebody's dyno chart with a short ram and then the stock intake w/K&N filter, and the stock intake was better all around. I'll have to look for that chart.
Je
the white hatch
Ok this is a dumb question but i know what cold air intake is but what is "short ram"?
Team 4R
Dr. DIY
"short ram", "ram air"........ just a few ways to designate the intake style that is a single pipe routed to an open-element filter located in your engine bay. basically this is a direct replacement to your stock airbox, usually keeping the same piping angles and filter location.
Je
the white hatch
Thank you porn moderator :nod:
Linguistics
Live Manikins
Okay, i got another one...
How much does your filter style matter
Team 4R
Dr. DIY
i read an article on this a little while back..... essentially the filter can vary your overall power by as much as 3-4hp. buying a $200 filter will net you bigger gains, but picking up a $20 one and giving up on a handful of horses seems like the much smarter choice to me......
