04 Civic + Aftermarket Deck Problem?
bxooo
So recently i just installed a new Sony Xplod deck for my stock one. So what i did was i bought a harness adapter and i soldered the color matching with each other. Except the sony had an extra blue and the adapter had 2 extra oranges ones. I plug it in and it turned on fine and was working, i tried the aux port and it didn't work. The song started to play but very small and then the deck shut off. Now i tried to connect it back but it won't turn on at all. The fuse was blown so i tried to swap another fuse in and it blew too. How do i fix this whats the problem?
Also when i added the new deck in, my speedometer is acting weird now. When i turn on the car the needles would start tapping alot and then stop. Anyknown cause of idea?
lowlife9
whatever you do don't connect the dimmer wire.
bxooo
Here are some of the photos i took, please help me and thankyou in advance!
http://i43.tinypic.com/35chnr8.jpg
http://i39.tinypic.com/105pk3m.jpg
http://i40.tinypic.com/k0k8if.jpg
http://i42.tinypic.com/f42xoi.jpg
For the last pic, i did not connect or solder that blue wire to anything because it was extra from the Sony side. Also i did not connect either 2 orange wire from the adapter.
After i had sodered them, i connected the old blue plug that was in the stock into the adapter which is the small white part in this photo. http://i39.tinypic.com/11185mf.jpg
i did nothing with the larger region and just left it there, it stopped working and no longer turns on. Anyway to fix this?
The wires that i soldered together are:
Black,Blue, Green, Green w/black line, Gray, Gray w/ black line, Yellow, Red, Purple, Purple w/ black line, White, White w/ black line
DB-Audio
i beleive the probalem is a short because what it looks like is you have not electrical taped any of the wires i would do this try it an see what happenes if that is not the problem then maybe it is the head unbit itself
