06 check engine light
513tim
engine light came on. code was to replace the engine coolant temp sensor, i did that and the next day the engine light came on again... same code. not sure what to check from here???
513tim
ok thank you. Im taking to my mechanic soon, its running fine and not running hot so it doesnt seem to be urgent. both radiator fans run constantly tho, even when the key is turned to "on"
What is the CEL code # that you're getting?
NikkiLauda
Thermostat. Probably stuck closed. Fans are doing theyre job.
