hi i just got a civic DX for my son but wound star, i change spark plug, distributor wiring, fuel filter and engine cover gasket kit also the O-ring seal between the camshaft and the distributor by doing all that i was sure to keep the 1st piston on top or at DTC point, any way the car will crank but not star so it may be the timing or the distributor wiring since i don't know to much about it i may installed wrong but i follow the Haney book, I'm still confused if i did it wrong, so please if any one have the diagram for this car on how to install the distributor cables or a pictures of the engine bay that i can see the positions i Will appreciated, thank you for your reply
P.S/ I also check the main fuse and is OK
