1992 Civic D16Z6 wont start
92_Civic
Im new to the honda scene and i have a 92 that wont start i tried everything i know it just cranks and cranks, its getting fuel, spark, and air if anyone has ideas let me know and the timing is correct
joegould29
does it have any compression?? do a compression test and let us know..
newtron63h
whats the last service work done to it?
92_Civic
the fourth cylinder was low on compression but even so the car should run with that being low i wonder if a valve could have been sunk because the last thing that was wrong is it didnt have any spark and i narrowed it down to the distributor and i put a brand new one in
92_Civic
yup checked it like a thousand times and its right i have no clue im about to rip the motor and tranny put and get a gsr swap or an H22 swap and be done with it
bensmoore
you checked for spark in all 4 cyl.? you checked for fuel pressure? you checked the engine timing? .. compression was low in cylinder number 4? How low was it ?
92_Civic
like 100 psi no i did not check the fuel pressure but the plugs are wet when i pull them out and it has spark in all four cylinders and engine timing is on to
bensmoore
well if you know you have spark to all 4 but the plugs are wet when you pull them out .. your ignition timing has to be off .... Thats all i can say . firing order 1-3-4-2 :(
