Beyer
1995 civic
Was running rough and Blowing smoke - appears to be white. It now runs smooth with new plugs, but still smokes.
No apparent water in oil.
No apparent oil in antifreeze.
Compression check was 190-220 on all 4 cylinders
#2 spark plug looked like the ceramic was broken so I put in new plugs. Now it runs better but still smokes and stinks.
#2 cylinder has highest compression.
#2 cylinder gunked up new plug in less than 15 minutes idle time.
#2 cylinder appears to have oil on top of piston using a flashlight and looking down spark plug hole.
What the hell is it? I thought head gasket, but have good compression and no apparent water in the oil. Valve stem seals?
