1996 Honda Civic Hatchback: Water Leaking into Driverside Floor Board
Dannyloski
Hey Guys,
The title pretty much says it all, I have a 1996 Honda Civic Hatchback (actually belongs to my cousin, he got it a few weeks ago). Anyway, water is leaking into the Driverside Floor Board, but we have no clue where its coming from. It hadn't rained since he got it, but now these past few days it has and he's facing this little problem.
He is the second owner of the car as it was bought from a first owner, so it's not like it's been through a lot of people/abuse. The car is completely stock, no modifications whatsoever, except for the Koni/Ground Control suspension we installed a few days ago (first mod).
Nowhere else is it wet, except for the Driverside Floor Board. The passenger, rear, and trunk/cargo floor boards are dry as they should be after a rainy day. The weatherstripping looks fine and it seals properly as it should. Windows shut all the way up, as they should. No cracks in any windows or the windshield.
Basically, I'm pretty much clueless as to what it could possibly be, so I'm here hoping someone might know or has had experience with this issue in the past and may suggest what they did to fix it. I had searched and found a thread where someone said there was a recall on 1996-1997 Civics about water leaking into the cabin due to insufficient sealer on the body seams. However, after checking with the VIN# this recall does not apply to this 1996 Hatchback.
Any ideas, thoughts, helpful comments, etc will be gladly appreciated. We plan on trying to find the source of where the leak is happening sometime this coming weekend by use a water hose to locate it. Hopefully this helps, but any tips are welcome.
Thanks for looking,
Danny
PS. Sorry for the long post, just wanted to be as descriptive as possible.
ichibahn
Did you get any results? I have a similar problem, only I have coolant leaking into my driver's side floorboard. Nowhere else, though... I was thinking it must be the heater core, but I was under the impression that if that was the case it would be happening on the passenger side?
Heater core is leaking.
Dannyloski
Sorry haven't had a chance to check it out, been too busy and since it's my cousin's car and not mine I'm not able to try anything until he comes by.
My cousin's issue is water and happens when it rains, not coolant. Coolant would be heater core hose leak or something like RonJ mentioned.
eiescobedo
1996 hatchback leak
im having the same problem but its on the passenger side. ive noticed it only leaks when it rains. my passenger seat will get soaked as well as the floor board. i noticed water on the door panel as well. my roof gets soaked also on the right front side by where the sun visor screws go. i was able to narrow it down as to where its leaking from, so im assuming its the weatherstrip that goes on the roof on the outside, right? i may be wrong but thats pretty much all i can think of. i would also appreciate any help to resolve this cause after it rains, sun comes out and the inside of my car gets humid and its starting to smell pretty bad. :x thanks again for any help!
