2000 d16y7 engine harness work on a b18b1
envyblackops
Had a question soon put a b18b1 in my coupe 2000 Civic Dx d16y7 wanna use the engine harness on the b18b1 will it connect to every plug on the LS swap , LS swap comes with everything and wanted to make sure before I buy a 2000 integra engine harness and ecu ? Lmk asap please and thanks
You can reuse your Y7 engine harness. I did. You'll need to do some modifications to it and will need the correct ECU but the harness should still work.
envyblackops
Okay goodlooking and what modifications I need to do ? So I Know [emoji1612]xplod3r [emoji1612] I got the right ecu
envyblackops
Wanna be obd2b and also run that ecu in the picture with my old harness basically wanna be stock to pass inspection then I'll plug up my downstep with p28 but first wanna know which harness I can use 2000 integra engine harness or 2000 civic si harness for b series lmk asap
envyblackops
I got a 2000 Dx coupe d16y7 soon swap it out but wanted to know if I get a VTec gsr swap do I need a 2000 Honda Civic si (EM1) b series VTec harness just asking
