2000 honda civic ex: Hunting idle
hotrod
hey i am new to this and i just got out of school trying to go to college so i got low money and i cant get my car working . ok its like this runs good till it get warm then when you stop it idles up on done and surges really bad i put a new converter on the exust and i put new throotle body sensor idle air control is new and still didnt fix it can any one please help me asap thanks
Any CEL codes?
Did you install a new TPS and, if so, did you calibrate it?
Have you checked for a disconnected vacuum hose?
Have you tried bleeding the cooling system?
hotrod
the code is p0505 and the other one is p0505pd i did not calibrate nothing and no vacuum leaks and there is no were to bleed th cooling system
Can you kill the warm idling engine by covering the top of the throttle body with your hand?
When the TPS is replaced, you must calibrate its voltage: 0.5V closed throttle, 4.5V WOT.
hotrod
i can cover the throttle body with my hand and it dies if i unplug the top senser my car shut off dont no if that help you guess can text me at 931-623-8550 going to work on it today so i will be outside i cant afford to take it in
