2001 5-speed trans swap. can i ?
nyghtryder
why would you want to? I cant see this being any type of an upgrade. Regardless there are two transmissions used for both engines the KA5MT and the KL5MT as far as I can tell they are interchangable.
Chris.
Stickin' it to the man
there is no point in doing so unless your current trans is shot.... or your looking for lower miles.... but still. unless your current trans is shot theres no point in doing this. the gears are exacly the same
Kaotic_Zeus
Most hated man
are you absolutely sure?
last time i checked, the ex manual 1st gear is shorter than the lx/dx 1st gear.
Chris.
not short enough to notice a differnece
Chris.
Very expensive! Very hard! Do not try this at home!
what?
expensive? how? you can get a trans for like 300 bux. swap it in a day. a few hand tools and an impact gun and your good.
and please resize your signature to 500x100
it is WAY to large. this is your first warning.
j.steimer04
4Dr Pimpin
what?
How about all the work with the clutch assembly? That cant come cheap, and it sure would be hard to do.
sr6000
still a D
It isn't hard to do at all. You just need a little mechanical know-how. That's all. Clutches are easy to work on. It's the clutch packs inside an Automatic that will through you for a loop
Kaotic_Zeus
Most hated man
two people with decent variety of tools and a good shop jack, with the whole day to work on it should be good enough.
Chris.
cheap? you reuse the clutch you have. all your doing is swapping transmissions. you dont even need to touch the clutch assembly.
Kaotic_Zeus
Most hated man
might as well swap the clutch and flywheel for something nicer since the tranny is out
toneekay
Rubbin on yo booty
Is the OP swapping from auto to manual? That's the question!
jonathan2006
D17A2 User
if you buy my tranny it comes with aperfectly good clutch and flywheel
just need a throw out bearing
