Tina
I have been seeing a small leak spot on the ground since the end of winter did not think it was coming from my car until recently when I put cardboard underneath.
I'm barely loosing any coolant and temperature has never risen stays steady below the half way point. Don't see any sign of coolant leaking when I look under the hood and don't hear any weird sounds. My leak is on the driver side it's always next to the front tire, after driving when I get home and look under the car I can see light drops of coolant can't quite pin point where it's dripping from. Not sure if it would be the water pump or maybe a hose . Has anyone ever had a coolant leak on the driver side?
6/6/16- I started my car today, opened the hood and let it run till it was completely warmed up, didn't see any drops of coolant dripping underneathe the car while car was running. The only spot I could see that looked wet was near the rear of where the engine is almost under where the end of the timing belt cover is. Checked hoses they all felt fine no wetness anywhere on them.
Will hopefully get it jacked up while at work to get a better look underneath
Thanks
Thanks
