Engineering
Engine Type: In-Line 4-Cylinder
Engine Block/Cylinder Head: Aluminum-Alloy
Displacement (cc): 1668
Horsepower @ rpm (SAE net): 127 @ 6300
Torque (lb.-ft. @ rpm): 114 @ 4800
Bore and Stroke (mm): 75 x 94.4
Compression Ratio: 9.9:1
Valve Train: 16-Valve SOHC VTEC®
Multi-Point Fuel Injection
Front-Wheel Drive
CARB Emissions Rating: ULEV
Direct Ignition System with Immobilizer
110, 000-Mile Tune-Up Interval
BACK TO TOP
Transmission
5-Speed Manual Transmission
4-Speed Automatic Transmission (available)
BACK TO TOP
Body/Suspension/Chassis
Unit-Body Construction
Control-Link MacPherson Strut Front Suspension
Reactive-Link Double Wishbone Rear Suspension
Stabilizer Bar (mm., front/rear): 15.9 / 12.0
Power-Assisted Rack-and-Pinion Steering
Steering Wheel Turns, Lock-to-Lock: 2.79
Steering Ratio: 14.71
Turning Diameter, Curb-to-Curb (ft.): 35.4
Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in., front/rear): 10.3 / 7.8
Wheels: 15" Alloy
All-Season Tires: P195 / 60 R15 87H
Compact Spare Tire
BACK TO TOP
Interior Measurements
Headroom (in., front/rear): 36.9 / 35.0
Legroom (in., front/rear): 42.5 / 32.8
Shoulder Room (in., front/rear): 52.8 / 52.6
Hiproom (in., front/rear): 50.2 / 46.7
Cargo Volume (cu. ft.): 12.9
Passenger Volume (cu. ft.): 83
Seating Capacity: 5
BACK TO TOP
Exterior Measurements
Wheelbase (in.): 103.1
Length (in.): 175.4
Height (in.): 55.1
Width (in.): 66.7
Track (in., front/rear): 57.8 / 57.8
Curb Weight (lbs., MT/AT): 2597 / 2657
Weight Distribution (%, front/rear, MT): 59 / 41
Weight Distribution (%, front/rear, AT): 60 / 40
BACK TO TOP
EPA Mileage Estimates/Capacities*
5-Speed Manual (City/Highway): 32 / 37
4-Speed Automatic (City/Highway): 31 / 38
Crankcase (qt.): 4.4
Coolant System (qt., MT/AT): 5.2 / 5.1
Fuel (gal.): 13.2
Required Fuel: Regular Unleaded
* Based on 2005 EPA Mileage estimates. Use for comparison purposes only. Actual mileage may vary.
BACK TO TOP
Safety
3-Point Seat Belts at all Seating Positions
Front 3-Point Seat Belts with Automatic Tensioning System
Dual-Stage Front Airbags (SRS)
Front Side Airbags with Passenger-Side Occupant Position Detection System (OPDS): Available
Anti-Lock Braking System (ABS)
Side-Impact Door Beams
Lower Anchors and Tethers for Children (LATCH)
Immobilizer Theft-Deterrent System
Emergency Trunk Opener
BACK TO TOP
Exterior Features
Power Moonroof with Tilt Feature
Integrated-Rear Window Antenna
Remote Entry System
Dual Power Mirrors: Body-Colored
Variable Intermittent Windshield Wipers
Honeycomb Mesh Grille
Impact-Absorbing Body-Colored Bumpers
Multi-Reflector Halogen Headlights
Tinted Glass
Body-Colored Door Handles
Trunk Garnish: Body-Colored
BACK TO TOP
Comfort And Convenience
Air Conditioning with Air-Filtration System
Power Windows with Auto-Down Driver's Window: Illuminated Driver's Switch
Power Door Locks
Cruise Control
Beverage Holders: Front with Lid / Rear
Center Console with Armrest and Storage Compartment
Door-Pocket Storage Bins
Passenger-Side Seatback Pocket
Coin Box
Adjustable Steering Column
Remote Fuel Filler Door Release
Remote Trunk Release with Lock
Headlights-On Reminder
Driver's and Front Passenger's Vanity Mirrors
Map Lights
Floor Mats
12-Volt Power Outlet
Driver's Footrest
Rear Window Defroster with Timer
Cargo Area Light
Cargo Net
BACK TO TOP
Seating
Driver's Seat with Manual Height Adjustment
Reclining Front Seatbacks
Adjustable Outboard Head Restraints
60/40 Split Fold-Down Rear Seatback with Lock
Passenger-Side Walk-In Feature: with Memory
BACK TO TOP
Audio Systems
AM/FM/CD Audio System with 6 Speakers and Clock
BACK TO TOP
Instrumentation
Backlit Instrument Panel
Tachometer
Digital Odometer and Digital Trip Meters (2)
Fuel and Coolant Temperature Gauges
Trunk-Open Indicator Light
Low-Fuel and Low-Oil Pressure Indicator Lights
Maintenance Interval Indicator
Illuminated Ignition Switch
if repost sorry im bored
Front-Wheel Drive
BACK TO TOP
Transmission
BACK TO TOP
Wheels: 15" Alloy
Compact Spare Tire
BACK TO TOP
Seating Capacity: 5
BACK TO TOP
Length (in.): 175.4
Height (in.): 55.1
Width (in.): 66.7
BACK TO TOP
Fuel (gal.): 13.2
BACK TO TOP
Safety
BACK TO TOP
Exterior Features
Remote Entry System
Tinted Glass
BACK TO TOP
Power Door Locks
Cruise Control
Coin Box
Map Lights
Floor Mats
Driver's Footrest
Cargo Area Light
Cargo Net
BACK TO TOP
Seating
BACK TO TOP
Audio Systems
BACK TO TOP
Instrumentation
Tachometer
