which power to weight ratio is better between these two cars? which would win if they were both bone stock with the same driver?
and also whats the top speed of a 91 STD hatch?
who said anything about racing?
Ummm You did...who said anything about racing?
no b-swap. but you can h-swap it. ive seen it done.the B20 in those are not the same as later B series, non of the parts swap.
means no head swap, nothing.
you cannot swap the early B20s(and B21s) into a civic or integra
your not listening right, the stock b20 in the lude will not fit into any other honda out there is what Steve is saying.no b-swap. but you can h-swap it. ive seen it done.
ohhhh my badyour not listening right, the stock b20 in the lude will not fit into any other honda out there is what Steve is saying.
91 preludes come with B series engines.no b-swap. but you can h-swap it. ive seen it done.
the 2.0si's are one of the nicest cars i've ever been in. yah, it might be old, but the interior felt good, the ride felt good, the engine (not a beat to s**t one) hummed and felt good. I would be driving one if there was actualy an aftermarket base for it. It had the lowest hoodline of cars in it's generation 2nd to the nsx i think.
comparing it to a base model std... o.0
it's like asking a fit to beat an s2000 in a 1/4 mile race.
powerweight ratio is important, but to an extent when ur comparing cars of similar power and setups.
comparing a long geared 80ish hp car to a shorter geared 130-140hp car despite a 600lb difference is like assuming an eg-6 can be a bmw m5 in a striaghtline just cuz the eg6 has a lower weight value.
not bad.....not too bad at all.In 1987, Road & Track published a test summary that shows the 1988 Honda Prelude 2.0Si 4WS out slalomed every car of that year, including all Lamborghinis, Ferraris, and Porsches. It went through the slalom at 65.5 mph (105 km/h), an amazing result for the time. For reference, the 1988 Corvette took the same course at 64.9 mph (104 km/h).
the prelude B20s DONT swap, there is a RARE JDM B20 for the 3g accord.
im sure they can be swapped, but
1. wont be worth the effort
2. custom mounts would be needed.
those a20 blocks are almost bullet proof, cast iron block ftw
