91 Honda Accord 2.2l auto
stevenmichaelmcb
Hello. Just bought and suddenly temp gauge rocketed up so turned off. Had plenty of coolant in it. Started up and really bad engine idle speed the goes up and down up and down?? Winter and then. Turned on heat and blows out cold air?? Temp not as hot? Please any idea??
HeX
Authoritah, respected.
:huh: You dont make much sense. Are you aware that you created a new profile and posted on a CIVIC forum, not an Accord forum? Thats why there's no Accord section and you posted in the wrong area. You might have some sort of engine coolant system problem and more, but you should look for answers in an Accord forum.
Diana Nam
yea what hex said but anyways i would replace the water pump and change the thermostat
dancam
Member
BUt why? If he cant type he should take it to a mechanic. He could also just have a bad ground.
Diana Nam
its not electrical problem that causeing it to over heat and have no heat. that would be the water pump and the thermostat. but personally i always check the water pump by runnign the car without the thermostat if it still over heats water pump is no good and it starting to fail. if it stop over heating and he gets heat then the thermostat is stuck closed.
