hondaNothyundai
I have a 1994 civic ex 1.6l sohc d16z6. Vtec. It overheated about 9the months ago and I still haven't figured it out. I took it to a shop and had them replace the water pump and timing belt. I also replaced the radiator, thermostat(twice), a radiator hose that split, the coolant reservoir. I continue to have the same issue though. After I bleed the cooling system it acts fine. Then after about 30 miles the temp gauge slowly rises from normal(1/4 way up) to 3/4 by hot and drops. If I re bleed it stops. If I keep driving it continues but it stays up toward hot longer and more often. Then when I get home it is either spraying/leaking out of the overflow tank lid or has been leaking from there. I have been asking friends and coworkers and they said to check for head gasket symptoms and that doesn't appear to be the issue. Please help!!!!!! Thanks.
