silentwhisper
I have an automatic tranny and have done quite a bit of research on this swap. Being that i don't expect to race this thing, im gonna do a head swap. Everyone says it will bolt in just fine, but i need a VTEC distributor and a P28 ECU. I also need to wire in a VTEC solenoid and use a 4-wire O2 sensor instead of a one wire.
My concerns for this swap are:
Will my existing wiring harness be difficult to modify for the new head?
Should i upgrade my fuel injectors to the 210 cc?
Will the VTEC head gasket line up with my original block?
Is using a new camshaft with a Y8 cam gear the best way to go?
Will i lose power by keeping a 68mm throttlebody or upgrade?
