instead of buying a whole coilover kit.. i was wondering if i can just by the coilover springs off ebay and swap them out with the stock springs on the car...ebay has adjustable coilovers......
Please and thank you
thank you...i dnt mean a full coilover set i mean just the springs itself to replace the stock springs......so ebay isnt good? i just want something to give my ride a better look im not racing or anything
You cannot use springs from a coilover setup on your OE designed shocks. The springs from coilovers have a flat top and bottom. The bottom of the spring is flat because the spring perch it rests on is flat. Whereas on a typical shock/spring setup, the spring perch has a grove in which the end of the spring sits snug in. Another reason they can't be used is because coilover springs are generally miuch much shorter than even a regular lowering spring. Most coilver springs are about 6"-8" in length unsprung. Where as a lowering springs could be 12" and up in length unsprung.
Coilover spring. Notice the spring sits flat on the spring perch.
Lowering spring. Notice the very end of the spring is not flat. The coil itself is round.
Thanks civic49.... that other Guy is a d**k...but I can get some under 600 that's a bet
Sent from my Droid using Tapatalk
He's not being a d**k, he's trying to help you from going down the wrong path that so many have done and regret.
If you're tight on money, you can get a good shock/spring setup anywhere from $350-$500.
If you want coilovers, you're looking at $550+.
Stay away from any no name, super cheap suspension products.
