It gets really f**king annoying when you dont have it too, i need to find a stock 96-98 so i can hide ityou will loose your keyless entry if you have it...
96-98 integrated into cd player
99-00 separate door unit
That's easy to fix though, if you have small hands. it took me 30 mins to fix when i replaced the stock radio in my '96 EXAlso you're dome light would not work.
this is what i thought also. when you buy a wire harness adapter for aftermarket radio doesnt the kit say 96-00 civic??all the plugs for the radio are the same from 96-00
I've owned a 96 EX and a '99 EX and the harnesses were differentall the plugs for the radio are the same from 96-00
If i remember correctly you have to jump pin B8 with pin B14 in the green harness behind the radio.Damm i didn't know about the keyless entry I was wondering about that. Whenever I bought my car it already had an aftermarket deck and the previous owner had a cheap alarm just so it would open the doors, but my dome light doesn't work unles you manually put it on. That sucks, any way to fix it????
