Abnormally low gas mileage.
young_
out on bail
So I just got back from a friends house and he lives an hour away. The drive is an hour for 50.9 miles. I filled up before I left, and then went there and back. It's all interstate driving. So for a total of 101.8 miles, I used almost half a tank of gas. Five gallons to be exact. So 101.8 miles divided by five gallons of gas = 20.36 mpg.
That's extremely low for a 1996 Honda civic ex, stick shift, with only an aftermarket intake and a header.
I have a CEL on for my downstream o2 sensor, and I replaced it with a Bosch o2 sensor but can't get the code to go away. I've tried all the ways to clear it. Hood ecu fuse, negative battery terminal, etc.
No real performance issues, exhaust doesn't smell like its running rich.
I know I have a small exhaust leak at the header from shitty installation (friend of mine cross threaded the bolt onto the stud so it doesn't seal all the way at one point.
The only other issue with the car is the second gear synchro is bad and sometimes second pops out, but I don't see how that could be related. But I figure it's worth mentioning.
Tire pressure is at spec all the way around. Car has a relatively fresh tune up. Plugs, wires, cap, rotor, fuel filter, and... Yeah that's it.
I also know the air filter needs to be replaced soon, but could it, alone, cause such low gas mileage?
Any ideas?
I know I have a small exhaust leak at the header from s***ty installation (friend of mine cross threaded the bolt onto the stud so it doesn't seal all the way at one point.
This^ is almost surely the problem. Fix the leak.
young_
out on bail
Didn't think it could cause that much of a drop in gas mileage. I'll get to it, thanks Ron!
The primary O2 sensor sends it's information to the ECU, which uses the information to adjust the fuel trim. When the O2 sensor reads high O2 levels (=lean), such as would falsely happen when there is a header leak, the ECU tells the fuel injectors to pump massive amounts of fuel into the cylinders. Therefore, even though the O2 sensor is constantly reading a lean condition due to the exhaust leak, your engine is actually running extremely rich because the fuel injectors are maxing out on fuel output.
Fix this problem ASAP.
xxBLOOD88SHOTxx
Surge Master
Was it you or someone else we were trying to figure out if you had a clogged cat?
Ron is probably right, but damn that like a drop of 12-15 mpg.
young_
out on bail
Ah, makes sense. Thanks for your input Ron! I'll probably source a stock replacement for a quick fix.
young_
out on bail
That was me. And yeah, crazy low gas mileage! Cost me forty bucks to go down there and back.
EJackBauer8
40$? How do you figure? Unless you live in an area where gas is 8$ a gallon which is nowhere in the United States. I'm not trying bash, just want to see your reasoning.
young_
out on bail
Eh, it was more like 36 or something. It cost me 20 bucks to fill up from right below half where I was before I left, and like 16 to fill back up. So I rounded up. Lol
lethal6
Your Mom's Moderator
Lol. The fill up before you left doesn't count. The fill up AFTER you got back is what counts towards the trip. The fill before is gas that was already used for something prior so technically it cost you $16 to go there and back. :thumbsup
JohnS.
BANGARANG
I know I have very small leak where my cat and header meet and I still get 30+mpg. I can hear it when I accelerate.
If your CEL is still on for the o2 sensor, it's still telling your ECU false information, no? Only until the CEL is cleared will it go back to normal?
How close is the leak to your primary O2 sensor?
The OP says his code is for the secondary O2 sensor, which does not contribute to the fuel trim. It would be nice, however, for the OP to post the code to verify.
young_
out on bail
P0141 circuit heater malfunction downstream o2 sensor.
JohnS.
BANGARANG
Inches? I forget off the top of my head since its been a while since I've actually looked at the end of the header... But it's close.
Aah I read that too quick.
You probably don't have an exhaust leak there. Otherwise, the engine would be running rich and you'd be experiencing poor gas mileage.
young_
out on bail
Like me! :lol:
HeX
Authoritah, respected.
Have the CEL code cleared and it should make a difference in your MPG. My local AutoZone stores offer that service for free. FYI, Ive done some recent research on O2 sensor brands and Bosch ranks quite low. Our Civics use NTk plugs (made by NGK). It may be too late to return your Bosch O2, so remember to use NTK when the Bosch fails.
If you want some more tips about improving your overall MPG, click on my signature.
