In the engine bay, you will see two coolant hoses that connect to the firewall to circulate coolant through the heater core. The hose where coolant enters the heater core has the valve associated with it. Use the first picture in the diagram as a reference. Just make sure that the valve is fully closed. You wouldn't want to recharge the A/C if the real problem is that the heater is always on.i can't find the heater hose valve, can you tell me where it would be generally located?
You opened the valves when the gauge set was hooked up to the system??? Why??? Don't do this!I ran the manifold gauge again and this time turned the knobs on the low and high side on the gauge. the blue jumped to to the 'retard' section, and the red was set at 130F.
All of the refrigerant have leak sealer. Is there a brand you recommend?If the heater hose valve is fully closed when it is supposed to be, then you should try adding some refrigerant to the system. The fact that the refrigerant level is low would indicate at least a small slow leak, so if the A/C soon starts to blow warm again after adding refrigerant, then next time add refrigerant that contains some indicator dye that will allow you to pinpoint the leak. Also, never use any refrigerant containing a leak sealer.
Click here for a general guide for adding refrigerant to your system. Note that you probably will not need to add the entire can of refrigerant and overfilling the system would be bad because you would need to have the system drained, evacuated, and refilled. You would also need to replace the receiver/dryer. Therefore, multiple times during the refill procedure, close the low side valve (where refrigerant is being added) to make low and high side system readings. I would recommend that you stop adding refrigerant when the low side reads about 45 PSI, if the night outside temperature is the same as when you first measured refrigerant pressures of the system.
I am sorry. Have I done damage to the condenser?You opened the valves when the gauge set was hooked up to the system??? Why??? Don't do this!
The valves must remain closed. You released refrigerant from the A/C system into the atmosphere. You also may have allowed air into the system (=bad). Why did you do this? How long did you leave the valves opened?I am sorry. Have I done damage to the condenser?
A couple of seconds, max maybe 5 seconds. I thought maybe I would get an accurate reading.The valves must remain closed. You released refrigerant from the A/C system into the atmosphere. You also may have allowed air into the system (=bad). Why did you do this? How long did you leave the valves opened?
Do I need to vacuum the whole unit?
Why did you think your previous readings were inaccurate? I am not sure what your idea was here. Please clarify.A couple of seconds, max maybe 5 seconds. I thought maybe I would get an accurate reading.
I read the information on post #23, makes sense.The gauges only measure pressure in a closed system (=valves closed). Tonight, measure the low and high side pressures again. Comparisons with last night pressures may tell you whether or not the system must be drained and evacuated.
Did you read info at the link I posted in post #23?
I have seen basic R134a refrigerant (no sealant) sold even at Walmart.
It's my mistake, I didn't realize that the yellow hose is open to the atmosphere.Why did you think your previous readings were inaccurate? I am not sure what your idea was here. Please clarify.
The yellow valve must be fully closed as well. Was it open last night when you made any of the measurements you posted?It's my mistake, I didn't realize that the yellow hose is open to the atmosphere.
cool air (just as before), not cold.95F. Is any cold air coming out of the vents? How does the vent air compare to before you opened the valves?
it was closed, has been closed at all times.The yellow valve must be fully closed as well. Was it open last night when you made any of the measurements you posted?
Redo the pressure measurements tonight when the temp is similar to last night's temp. If the readings are similar, then add refrigerant until the low side reads 45PSI. You will need to close the low side valve multiple times while adding refrigerant to ensure that you do not overfill the system. Review the post 23 instructions before starting the refill process. If you have any specific questions, post them.cool air (just as before), not cold.
