See-Tee-R
So two weeks ago, I had an idle problem. (I dont have a tachometer, so I dont know exactly how many RPMS) Basically the idle went up and down as if I was holding down the gas and letting go continuously. A Check engine light popped up and I got the code, It happened to be a IACV. So I cleaned my IACV, everything worked perfectly, fixed the idle problem, and CEL went away.
Heres the bad news... So I find out that I'm leaking oil under my distributor, and research tells me that it is my dizzy leaking the oil. So I mark the dizzy with a screw driver, remove it, change the o-ring but in the process I accidentally flipped the fin (part that goes into camshaft) so basically I figured that since it can only go in 1 way, I switched it into position and put it back in (Is it possible that the turning of the fin can affect my idle?). Lined up my bolts for the dizzy and tightened everything up. I tried to start the car, and no crank, turned out to be a dead battery, so I replace the battery, and now it starts.
The problem is that the idle problem is back, and worse than before. What is the problem now? Vacuum leak? IACV AGAIN? Dizzy? That fin inside the dizzy? timing? battery?
Car: 2000 Civic DX Hatchback
Engine: D16Y7
Transmission: Automatic
Please help me out asap, this car is my daily driver, and Im pretty lost without it. If all else fails, Im gonna have to bring it into the dealership
Engine: D16Y7
