calpolyarc
2001 Civic. When I bought the car I had an anti-theft device installed. It's a coded chip card that I have to insert into a card holder before I can start the car. It's been acting up lately (14 years old!) so I thought I'd tamper with it... bad idea. First thing I noticed is that the way it was installed was by simply cutting the blackw/ white stripe wire in the steering column and connecting the controller to the two ends of that wire, thus interrupting it. See diagram:
So I thought hey, if I just reconnect the black w/ white stripe wire together and remove the controller I should be good to go. So I did and the car actually started! Twice! But that was yesterday, this morning it wouldn't start. It tries to turn over but doesn't. I re-installed the anti-theft controller and get the same result, tries to turn over but doesn't start.
While researching I came across this Honda Service Bulletin: http://www.hondalac.com/service/Bulletins/x01-053e.pdf which says that this is the correct behavior for an 01 Civic if you try to start the engine with a non-programmed ignition key. Page 2: "If you try to start the engine with a nonprogrammed ignition key, the engine cranks, but it cannot start."
My key is programmed, so I'm wondering if by tampering with the anti-theft device if I somehow screwed with the programming in the ECM/PCM/ECU ??
The anti-theft device I tampered with appears to be after market, so I'm not sure how it relates to the ECM.
Any ideas on how to fix this?
Thanks.
Thanks.
