I am not 100% sure if there are any b20's that make 200 HP but I do know there is an F20b that does (specs below). At some point I want to do an f20b swap and I will post with updates as I get further along with it.
F20B - info & specs
This engine series was used in the CF4, CF5, CF9, CL3 Honda Accord and Honda Torneo from Japan. It uses a DOHC VTEC cylinder head similar to the H22A found in the Prelude but was designed to comply with many countries' sub-2.0 liter tax. The automatic transmission versions received the lower hp version (180 hp), as it was tuned for more mid-range torque than its manual transmission counterpart. The F20B manual version also utilized stronger cams, intake and throttle body from the H22 type S. The difference between f20b manual (200 hp) and auto (180 hp) is cams, intake, throttle body and the gearbox for manual come with t2t4.
Specifications
Accord SiR wagon, SiR-T F20B 97-01 2.0 L
Valve train: four-cylinder, DOHC VTEC, 16-valve
Bore: 85.0 mm
Stroke: 88.0 mm
Displacement: 1997 cc
Torque: 145 lb·ft (197 N·m) @ 5500 rpm
Horsepower: 200 hp (150 kW) @ 7000 rpm
Red line: 7400 rpm
Compression: 11.0:1
Fuel control: OBD-2
