Pretty sure that's a Honda thing. My needle depends on the incline of the hill I'm ascending/descending.
If I'm on flat ground and have a half of tank and go up a steep hill... needle reads like a quarter tank.
If I'm on flat ground and have a half of tank and go down a steep hill... needle reads like 3/4 tank.
Some symptoms can be misfiring or lean running conditions, which can set the CEL, also if the car stumbles or struggles under heavy acceleration that could be a partially clogged fuel filter.I am just wondering how to check for a bad fuel filter. Are there any symptoms driving and if replaced, will I notice any improvement?
basically what he said....if you put your foot down on the gas and barely go anywhere its probably a clogged fuel filter....i had that problem with mine. very easy to replace just make sure you releive the fuel system pressure first. and that bolt on the filter is hard as f*** to get off or maybe mine was just stuck....Some symptoms can be misfiring or lean running conditions, which can set the CEL, also if the car stumbles or struggles under heavy acceleration that could be a partially clogged fuel filter.
If you say those bolts are hard to crack, try using an impact wrench/gun. My electric portable impact gun (mastercraft brand) helped me a lot to remove the bolts on mine.basically what he said....if you put your foot down on the gas and barely go anywhere its probably a clogged fuel filter....i had that problem with mine. very easy to replace just make sure you releive the fuel system pressure first. and that bolt on the filter is hard as f*** to get off or maybe mine was just stuck....
