Battery
dukeum3
When you put a test light on your positive terminal when everything is hooked up right isn't the light suppose to light up ? Or hondas don't do that ? I'm purty sure all cars postive terminal should light up the tester right ?
Once I put the terminal on the positive post is doesn't light up no more but when the terminal is off thr post my grounds to the fuse box light up n the terminal its like there's a short internal where the positive connector is on the coil
Sent from my SCH-S968C using Tapatalk
HeX
Authoritah, respected.
Have you made sure your ground is making clean contact? When using your tester, are you grounding to the battery or also trying the chassis or engine as a ground?
This seems to be the week of electrical issues. Don't feel alone because I believe you're the 4th or 5th and I was one of them.
dukeum3
I'm ground to a screw it's making a perfect ground contact n forreal it sucks when its a electric problem there is a lot to try to track
dukeum3
What ground would I be looking at the ground from the chassis to the head , chassis to on top of transmission , or battery to chassis
